New member needing help.
Fagan123
Post by Fagan123 » Sun Dec 28, 2014 4:32 pm
Hello, been a member for a while now but this is my first post. Busy restoring a KJA and in the process of removing the cab. Think I have everything disconnected but have hit a problem with the brake master cylinder. Don't want to drain the brake fluid but can't work out how to disconnect the master cylinder from the cab. Do I take out the four bolts around the pedal inside the cab or is it the two on the master cylinder under the bonnet? Have solved most problems by going through old posts but cannot find any reference to this. Any help would be most appreciated.
Ju
Re: New member needing help.
Post by Ju » Sun Dec 28, 2014 5:09 pm
Welcome to the club.
Plenty of people will be able to help you with this problem.
Post by Anton » Sun Dec 28, 2014 6:00 pm
:welcome2:
Rhinoman
Post by Rhinoman » Mon Dec 29, 2014 2:28 pm
You can just unbolt the master cylinder.
