Lwb samurai 1991 axles on sj413 1988
rodbourne
Post by rodbourne » Sun Dec 21, 2014 9:29 pm
Is this a straight swap??? Guessing they are wider. Not sure of any other benefits or problems. Cheers.
Re: Lwb samurai 1991 axles on sj413 1988
Post by ScottieJ » Sun Dec 21, 2014 9:44 pm
Lwb samurai axles are exactly the same as SWB samurai axles.
You'll have to cut the spring perches off move each one 40mm inboard. And make sure you keep them as the same angle as the standard ones.
I would suggest fitting the 413 diffs into the samurai axles as well as they have a slightly lower ratio.
rodbourne
Post by rodbourne » Sun Dec 21, 2014 10:09 pm
Cheers.
