Ford Fiesta...
Posted: Thu Dec 18, 2014 12:08 am
Anyone know how to persuade a Ford Fiesta that I don't want the freakin' aircon on every time I turn the key? This thing turns the aircon on no matter what the heater is set to (apart from off) which makes NO SENSE!
And the stop-start won't start the engine if the car is in gear. Again, that makes no sense - you have to depress the clutch fully to get the stop-start to restart the engine, so why does it have to be in neutral? Having it in first would make for a faster getaway from the lights, and on a few occasions it's messed me about and I ended up being honked at because I was trying to work out why it wouldn't start the engine. Of course, it was actually telling me on the little display, but I'm staring at the foot pedals, the steering rack, the key (which wouldn't turn) and feeling like a right bell.
The car will start normally if the car's in gear, so why not start from a "stop-start" stop? Makes as little sense to me as the car insisting I wanted aircon the other day, whilst happily telling me on the dash that it's 3 degrees C outside. FORD! I'm not a freakin' YETI !!!
I also can't work out why this thing is SO SLOW. It's a 1.5 TDI. It has 135ft-lb torque. So it's 5 down on the Yaris. The gearing is about the same (900rpm in 5th gives you 27mph, same as the yaris) it has roughly the same speeds in the other gears, it has roughly the same weight, and roughly the same HP. But it takes over 14 seconds to get to 60, where the Yaris takes 10.
Seriously, Ford - it's a nice car, it looks fabulous, but seriously - sort out these weirdnesses.
Oh, and for those of you wondering why I'm in a Ford Fiesta, a white van man decided to rearrange the back end of the Yaris recently, and the Fiesta is a courtesy car while his insurance company sorts out the Yaris. No-one was hurt, thankfully. But that means in the last year, the Yaris has been hit FOUR TIMES - twice up the butt, once while parked (bus hit and run, probably - bus coloured paint on the wheel) and some twat reversed into me the day after the first time it was hit up the butt.
Starting to think it's magnetic or something.
