SU Help
Posted: Sun Dec 07, 2014 5:37 pm
Very cliche, but long time reader first time poster
So a quick background, I brought my SJ as a blank canvas, rolling body with nothing in the engine bay. Already intrigued by the SU conversion, it happened that the G16 engine I picked up for it already had an SU on it but had 'carb problems'. While using British carbs might not seem like the done thing on this side of the world, being British born I was determined to get it running
Long story short, the piston was seized in the body and not even a hammer was going to persuade the 2 to seperate so that went in the bin. Picked up a pair of brand new HIF6's brought for a range rover and never used for a price too good to pass up, sold the extra one for almost as much as I paid for the pair, even better
Fitted the BDL needle I salvaged from the old carb until I could get a BFM.
So whats the problem your all asking..
Starts fine now, can tune it approximately cold, runs around 2000rpm on full choke, 900ish when first off choke, goes like a cut cat. But after warm up the idle wont drop much below 2000, even with the idle screw wound off the throttle stop, and we eventually get fuel pouring out the overflow.
Best info I could find is the suzuki pumps run 6-9psi, although I see no mention of anyone on here needing to use one I chucked a regulator on and still no change.
If I pull the return line off the pump I get a huge burst of pressure like opening a coke bottle. Blasted the compressor down the line and got a chunk of crud out the other end, stuck the tank end of the hose in a fuel can and engine seemed to run fine and plenty of fuel flow into the can, cleaned out the tank fitting also, reconnected everything and back to the same problem again.
It is possible, as the body had been sitting on a farm for X years with no engine, that the line is full of crap which keep dislodging and blocking the line, so I suppose running new line should be the first bet, and the cheapest since I have a ton of 3/16" copper line left over from brakes. Or prehaps has the pump gone haywire and somehow creating far too much pressure.
What are everyone elses thoughts? Would the float chamber overfilling increase the idle by that much, or do I need more air to be getting in somewhere too? I've dismantled and checked all the guts of the carb, checked float height, needle etc, and the carb had definately never been used anyway, drilled the vac advance on the correct side of the butterfly. Can't find any more vac leaks. Unless the overrun valve in the butterfly is opening on decelleration (i think thats what its supposed to do?) and then not closing again..that would probably cause high idle depending how much air flows thru it.
Anyway, novel over for now
Any thoughts, comments, more things I should check, preferably that don't require spending any more money
Thanks, Clive
Thanks, Clive
