Indicator problem..
- Josh-holden
Indicator problem..
The indicators are flashing fast on one side. Iv found that the hazard switch is a bit temperamental but indicators flash normal speed. Iv got led front indicators and cleaned all earths. Checked all bulbs. Anyone got an idea of what it could be? Any help would be great
- Ladaman
- Suzuki Guru
Re: Indicator problem..
When you put LED bulbs in, you need to change the flasher relay too.
- Josh-holden
Ok, does it matter about the side lights being led? Surely they would flash fast when the hazards are on?
- Ladaman
- Suzuki Guru
When I did mine, I changed to LED front and rear, side ones are normal bulbs.
I had to change the relay. Not sure if you've just changed the fronts. Can you try normal bulbs to make sure it's all okay?
- Josh-holden
Yes iv just changed the front indicators and side lights. Yes think i will try that. I cant figure out why they do different things on hazards and different speeds separate sides
