Starter Motor dead.
ferris
Starter Motor dead.
Post by ferris » Fri Sep 04, 2009 8:48 pm
My starter motor has suddanly died :cry: when i turn the key it just clicks. I tried tapping it with a hammer and managed to get it going once, but now its not having any of it.
Is it possible to fix it, if i take it apart? or is it just a case of getting a new one??
Henry
Re: Starter Motor dead.
Post by Henry » Fri Sep 04, 2009 8:50 pm
Yes it is possible to fix it yourself.
One question. What is the starter from? 413? 410?
deathbus
Post by deathbus » Fri Sep 04, 2009 10:32 pm
you sure your battery is ok?
starters click if the battery isnt strong enough.
ferris
Post by ferris » Fri Sep 04, 2009 10:56 pm
Its a 413.
The battery is ok.
Il take the starter out tomorrow see if i can bring it back to life.
Cheers for the reply's.
Henry
Post by Henry » Fri Sep 04, 2009 11:14 pm
muddy kev
Post by muddy kev » Sat Sep 05, 2009 7:23 am
hi, could just be voltage drop through the ignition switch, very common on suzukis.
try running another wire from the battery positive to the small slide on connector on the starter solenoid, if there are 2 of these just try 1 at a time. the other 1 is just 2 help cold starting so wont hurt if u get that 1, if it is wiring problem and not starter motor when u touch the terminal, with ignition off it will crank the engine, with ignition on it will fire up so make sure its out of gear,
cheers kev
ferris
Post by ferris » Sat Sep 05, 2009 7:19 pm
Cheers for the help guys.
I got home from work this afternoon with the full intention of striping the starter down to see if i could fix it. But i tried starting it first, and it started first time. Now it seems fine and works every time.
Sods law though, next time i drive out into the middle of nowhere it will probably start playing up again. :roll:
4eye
Post by 4eye » Sun Sep 06, 2009 8:03 pm
Well buddy...i should be back on the road soon...all i need is the shocks,but having trouble tracking them down... :oops:
Also debating weather to get pro comps all round for when i get my lift springs ...sorry for pinching your thread but any info or advice most appreciated! 8-)
my ride.........:4eye:
