rear springs
vit4x4
rear springs
Post by vit4x4 » Fri Aug 29, 2014 9:41 pm
hI the rear springs in my blitz are very harsh, they are 2 leaves + a short helper leaf, can I remove the short helper leaf to soften the ride, thank you again
Re: rear springs
Post by ScottieJ » Sat Aug 30, 2014 4:42 pm
You mean the flat leaf with clamps at each end? If you remove that you will get more axle wrap as it helps reduce this.
Or is it just another leaf but shorter? If so it might be an Add-a-leaf so yes you should be able to take it out.
vit4x4
Re: rear springs
Post by vit4x4 » Sat Aug 30, 2014 8:30 pm
thank you scottiej its a short spring but theres no clamps on it
