SJ410 Removing the dash
Posted: Sat Aug 16, 2014 9:25 am
Hi... does anyone know of a tutorial/video of how to remove the dash on a 1986 SJ410?
Cheers Lee
Cheers Lee
Home of all things Suzuki 4x4
https://suzukiclubuk.co.uk/forum/phpBB3/
https://suzukiclubuk.co.uk/forum/phpBB3/viewtopic.php?t=10864
Lash151 wrote:That's great, thank you... I need to sort out the heater... so that is perfect!
Cheers Lee
Well, It's not great... also there are a couple of hoses under the dash that aren't connected to anything... The wiring looks a bit iffy under there as well... looks like you can get to most things without taking the dash out though... and seeing as it's all fitted nicely, perhaps I won't take it out.Darrell wrote:Lash151 wrote:That's great, thank you... I need to sort out the heater... so that is perfect!
Cheers Lee
May I ask what's wrong with it.
The more I think about it, it does look like a hard job... and the dash is all fitted well, so I could easily make it worse... I think I can get to the heater hoses underneath, which might be a better idea.Darrell wrote:Take some pics we may be able to help. Taking the dash out looks a lot of work.
The heater only has 2 water pipes coming though the bulkhead.
"Bloody Halfords gave me the wrong filter" that sounds about right.
