Page 1 of 2
Which Suzuki Jimny engine? and cutting out engine problems
Posted: Thu Jul 10, 2014 8:20 pm
by Unclesparks
Hi, I'm new to the forum and I'm a new Jimny owner, In short I'm after 2 things. Firstly how do I identify what engine is in my model/year Jimny. Secondly I have a engine troubles. The last couple of trips out in the Jimny it has displayed the same symptoms, Gets hot, fluctuating RPM, stuttering juddering engine, then it dies, I let it cool down for 10-15 minutes then it starts up fine. I've read it might be either the crank shaft sensor, the cam shaft sensor or both but I need to identify the engine for the right parts. Can any one help or offer any further advice.
Re: Which Suzuki Jimny engine? and cutting out engine proble
Posted: Thu Jul 10, 2014 10:25 pm
by donkeychomp
Surely if you need spares for it just give the motor factors your reg number...
Has it got coolant in it? (Bit obvious but you never know).
Posted: Thu Jul 10, 2014 11:33 pm
by trotter
I have a early jimny 2000 W reg and a new cam sensor fixed the problem.
Around £40 from local motor factors. Its at the back of the head on the engine aka nearest the windscreen, unplug the wiring plug and think its held in by 1
12mm bolt.
Posted: Thu Jul 10, 2014 11:34 pm
by trotter
My one only has a cam sensor..
Rhinoman is the guy to ask about jimny's
Posted: Sat Jul 12, 2014 5:19 pm
by Rhinoman
M13 engine has flat top with a plastic cover over the plugs and coils. G13BB has an alloy cam cover with exposed coils. In any case the engine number will be on the V5c
Posted: Thu Jul 24, 2014 11:18 pm
by Unclesparks
Mine looks to be the G13BBas its the alloy top version. Where exactly is the cam sensor located? I've bought one now I just need to find it to fit it?
Posted: Thu Jul 24, 2014 11:28 pm
by Rhinoman
Its at the back of the head.
Posted: Sat Aug 30, 2014 4:01 pm
by windie
hello to every body i am a new member.and need help with your expertise just bought a 2002 jimny for my girl friend. she got a got knackerd engine.thats the car not the girl friend the engine is g13. and i have chance at a low mile m series twin cam engine none vvi would go in to my jimny cheers
Posted: Sat Aug 30, 2014 4:04 pm
by Rhinoman
It would be a complex swap and would need the gearbox, wring loom and ECUs as well as a number of other parts.
Posted: Sat Aug 30, 2014 4:09 pm
by windie
thanks for your advice i wil look for a g13 engine . i have a g13 engine its older than the original engine it has not got a crank senser at the front of the sump just under the pully could i modify it
