standard or su carb needed!!!!
Posted: Tue Sep 01, 2009 1:19 pm
by jameswilts
my friend has a sammi and is in desprit need of a new carb.
when he goes round corners the engine stalls and on tick over
the engine is reving realy low. he has cleaned everything and cheacked for
leaks. we are no master machanic's so any help would be greatly appriciated.
thanks
Re: standard or su carb needed!!!!
Posted: Tue Sep 01, 2009 5:34 pm
i think i have one but the chokes a bit fooked! perhaps if his has a good choke you could swap it over?
Scott
Posted: Tue Sep 01, 2009 6:37 pm
by jameswilts
think he will try anything mate!! at the mo his has a auto choke,
ant news on leaf springs? thanks
Posted: Tue Sep 01, 2009 7:34 pm
by Henry
Whats it for? I have a 410 one.
Posted: Tue Sep 01, 2009 9:27 pm
by liljitjit
hi if you have a look on difflock.com under suzuki they have some exellent info on both standard aisin carbs (how to strip and service) and on conversion to su . su is the way but you will need to fabricate a manifold adaptor or buy one from ebay as the stndard carb is a down draft and an su is side draft. I have had bothon my sammy and the su is best but i have just sourced a newer standard carb to fit whilst i remake my su adapter.!!! good luck. Oh just rememberd if you can find one a charade 1300 carb does fit with a little tweeking.
rich
Posted: Wed Sep 02, 2009 5:42 pm
by jameswilts
its a sammy 1.3 petrol i believe
Posted: Thu Sep 03, 2009 9:07 am
found the carb matey! will pop over to you this weekend!
