Blown out rear diff
shaw
Blown out rear diff
Post by shaw » Fri Jun 20, 2014 1:44 pm
hi. i got a suzuki sj413 with a blown rear diff. and woundered what the best thing to do about it is. cant find another 413 diff anywere and when i rung up rhino ray he said best thing to do was scrap it. :poke:
is the samurai diff a strt swap if i change the front as well?
if it aint jap, its crap!
shaw
Re: Blown out rear diff
Post by shaw » Fri Jun 20, 2014 2:36 pm
will the samurai diffs fit in the 413 axle or will i have to change the half shafts.
unless anyones got a spare sj 413 rear diff in the east sussex area.
Post by twiss » Fri Jun 20, 2014 2:43 pm
samurai diffs will fit but the ratios are different so you will have to change the front AND rear.
I probably know people with diffs around west sussex - one in worthing, one in chi and maybe one in crawley...
if you're interested let me know
shaw
Post by shaw » Fri Jun 20, 2014 3:14 pm
yea if you know someone with the normal 413 diff i would be very interested. cheers
Post by twiss » Fri Jun 20, 2014 5:03 pm
Ive asked around will let you know what i find
Post by andyrew » Fri Jun 20, 2014 5:20 pm
shaw wrote: when i rung up rhino ray he said best thing to do was scrap it. :poke: ?
Well thats abit of a dumb answer.
You should be able to find a pair of samurai diffs easily.
I have some front ones dont think ive got any rears tho
Post by Jordi » Fri Jun 20, 2014 7:43 pm
Probably get a set of axles for under £100
Sj410red
Post by Sj410red » Sat Jun 21, 2014 5:09 pm
Just found this on eBay sj413 rear diff item number is 171364242196
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Diff & Box high breather pipes
Front Diff guard
Sj410red
Post by Sj410red » Sat Jun 21, 2014 5:11 pm
Or a rear axle with diff for a tender more! Item number 281367101426
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
shaw
Post by shaw » Sun Jun 22, 2014 5:27 pm
yea theyre sammi ones tho. i would need a set to match the front and rear ratios.
think I might have secured a pair of axles tho. cheers for the help guys.
