hi all i am new to forums so please bear with me. i have a 2005 grand vitara xl7 2.0td it has a peugoet engine i think, great car i love it. however , the other day i wouldnt start :-( i plugged a fault reader in and below is what it said but im not sure what it all means.
i think its something to do with the fuel pump from the tank as i cant hear it run when i turn the ignition on. any help would be greatly appreciated
meta-info header:Error Codes
file version:1
type:5
time:1401727847960
codes:P0245,P2141,P2144,
codes_p:P3006,P2009,
codes_raw:43024521442141
codes_p_raw:47300620090000
Error Codes
P0245
Turbo/Super Charger Wastegate Solenoid "A" Low
Vehicle speed (Speed) 0 mi/h
PIDs supported [21 - 40] 00100000000000000000000000000000
Engine coolant temperature (ECT) 66 °F
Fuel Rail Pressure (diesel, or gasoline direct inject) (FRP2) 0.19743336623889438 Atm
MAF air flow rate (MAF) 2.58 g/s
Calculated engine load value (EngineLoad) 100.0 %
Engine RPM (RPM) 192 rpm
Intake manifold absolute pressure (MAP) 0.9772951628825272 Atm
P2141
Exhaust Gas Recirculation Throttle Control Circuit Low
P2144
Exhaust Gas Recirculation Vent Control Circuit Low
Pending Codes
P3006
P2009
Intake Manifold Runner Control Circuit Low
Raw values
Error Codes 43024521442141
Panding Codes 47300620090000
meta-info footer
Grand vitara xl7 2.0td wont start
Re: Grand vitara xl7 2.0td wont start
Don't know about all the error codes but the Grand Vitara 2.0td does seem to have an awful lot of immobilizer problems.
Hopefully "Rhinoman" will be able to help as he is the electronics expert on here and many other forums.
I know he is familiar with this common fault. (if this is the fault of course)
Other than that
to the club.
Other than that
Most of those fault codes are for a low signal, that would seem to indicate that you have a power feed missing somewhere. An immo problem should normally give you a flashing immo light, the Renault/Pug forums may be of more help.
