vitara lift
lewis1403
vitara lift
Post by lewis1403 » Tue Jun 03, 2014 5:30 pm
Hi looking for some advice want to lift my vitara but what way is best and most cost effective?
Not sure weather to just use suspension spacers how do these effect the drive?
Thanks lewis
Re: vitara lift
Post by donkeychomp » Tue Jun 03, 2014 10:13 pm
I've been looking into this. Personally I'm going with a 2" suspension lift kit from Bits4Vits. £102. No mods are needed. If you want to go higher then it gets complicated. Longer hoses, lengthening the gearsticks etc. And a body lift would be a pain in the arse to do. My plan is to get 31's on the Vit so with the sus lift I will also do a virtual lift (cutting out the wheel arches).
Hope this helps!
lewis1403
Re: vitara lift
Post by lewis1403 » Wed Jun 04, 2014 8:40 am
Hi thanks that was really helpful! Think I'm going to probably do the same, I just need a decent set of tyres should give it enough lift
Thanks
