wiring info
Posted: Tue May 06, 2014 6:42 pm
by neil atkins
Hi there my vitara 1992 was injection now its carberetor can someone tell me how to wire up the distributor from a carberetor model ignition module and coil in a word HELP Thanks Neil
Re: wiring info
Posted: Tue May 06, 2014 8:48 pm
by Darrell
I would just unplug the old main relay as it's not supplying anything now and connect the b/w to ignition coil as before.
Re: wiring info
Posted: Wed May 07, 2014 9:01 am
by neil atkins
Thanks darrell I have looked allmost every were I was just about to give in. It's been a long task for me to convert from injection to carberetor I hope I can get it sorted now Thanks Neil
Re: wiring info
Posted: Wed May 07, 2014 12:13 pm
by Ladaman
neil atkins wrote:It's been a long task for me to convert from injection to carberetor I hope I can get it sorted now Thanks Neil
Why would you want to do that?
Re: wiring info
Posted: Wed May 07, 2014 1:31 pm
by neil atkins
Hi there I did this because the ecu nackerd on me and could not get one
Re: wiring info
Posted: Sat May 10, 2014 7:56 am
by neil atkins
Hi there thanks for the info on the wireing it works fine but lost mt rev counter what do I need to get it working Thanks Neil
Re: wiring info
Posted: Sat May 10, 2014 11:05 am
by Darrell
Hopefully there is still the old brown with white tracer coming from the main wiring loom that went to the old coil. It came from the noise suppressor which I hope is still there, if so connect this to the coil negative terminal and see if that works.
Re: wiring info
Posted: Sun May 11, 2014 12:55 pm
by neil atkins
Thanks again Darrell put the wire on and the rev counter works Thanks Neil
Re: wiring info
Posted: Sun May 11, 2014 7:46 pm
by Rhinoman
neil atkins wrote:Hi there I did this because the ecu nackerd on me and could not get one
You could have spoken to me I do repairs and have exchange units.
