Horn u/s
bazza1949
Horn u/s
Post by bazza1949 » Mon Mar 31, 2014 1:07 pm
Horn not working .. checked fuse and relay both seem ok..what next ?
timwilks13
SCUK Website Padawan
Re: Horn u/s
Post by timwilks13 » Mon Mar 31, 2014 1:10 pm
if you have a meter check you have 12 volts across the horn when the button is pressed, if you do the horn is gone, if you dont check you have a good earth.
timwilks13
Re: Horn u/s
Post by timwilks13 » Mon Mar 31, 2014 5:09 pm
can also just test your horn with two wires to either side of a battery, what car is this for anyway? probably should have asked that first!
Re: Horn u/s
Post by Anton » Mon Mar 31, 2014 7:04 pm
Aren't horns permanent live, switched earth - for safety reasons? Something about not wanting live going through the steering wheel in case it causes a fire?
Cyprus Geoff
Re: Horn u/s
Post by Cyprus Geoff » Mon May 05, 2014 5:09 pm
Check earth on the steering column - this had be fooled for ages - in the end I used a wire on the column secured either side of the joint (near master cyl in engine bay) works brill now.
Re: Horn u/s
Post by Anton » Tue May 06, 2014 9:26 pm
:thumbup:
