radiator problem - fan switch>?
Posted: Fri Mar 28, 2014 1:13 pm
by fatdaz
just got a new rad for my vitara td commercial, and the part where the switch screws in isnt there!
can i use some sort of universal inline switch instead?
Re: radiator problem - fan switch>?
Posted: Fri Mar 28, 2014 2:58 pm
I used one like this... ebay special and used in combination with a relay
Posted: Fri Mar 28, 2014 11:01 pm
by fatdaz
thanks dude. why a relay?
is that the 30 quid one?
Posted: Fri Mar 28, 2014 11:05 pm
by fatdaz
i havnt measured the hoses yet but this one comes on at 90 degrees and off again at 80?
http://pages.ebay.com/link/?nav=item.vi ... 1185078563
Posted: Fri Mar 28, 2014 11:40 pm
Yeah you want your temp to hover between 80 and 90 thats fine... definitely measure the pipe first
As for the relay, the temp switch will switch the relay on, and the relay switches on the fan motor.
this saves the temp switch from having all the power for the fan put though it
Posted: Sat Mar 29, 2014 5:08 pm
by fatdaz
got ya, could you recommend a relay off ebay or the like? i wouldnt know what to get lol
its a 2 wire switch.
Posted: Sat Mar 29, 2014 5:40 pm
Click Here for Ebay Listing
you will need some wire, a fuse holder and a 30a fuse... and some crimp connectors (ring and spade)
For some more information on relays, read this page:
http://www.mp3car.com/the-faq-emporium/ ... it-up.html
Posted: Sun Mar 30, 2014 9:31 pm
by fatdaz
thanks dude, so at the moment is the standard fan switch in the rad taking all the power that the above relay would?
Posted: Sun Mar 30, 2014 10:46 pm
not sure on the TD setup... but possibly not.
You should be able to hear it click and activate when the engine gets to about 90*C, when the fan would usually activate
Posted: Mon Mar 31, 2014 9:10 pm
by fatdaz
sorted
all in and works as it should
thanks for your help
