SJ410 over heating
Posted: Sat Mar 15, 2014 8:18 pm
Thought I had a problem with it when I drove it home, but put it down to bad servicing, and decided to do all the bits.
So after a new set of plugs, leads, Oil and filter, air filter, fuel filter, rad cap, thermostat, and a full coolant flush, I thought I Was good to go.
But today, I took it on a long-ish run (15 miles), and after 10 mins, it soared up into the red, and I had to pull over.
It cooled down pretty quick, and I carried on.
But within another few mins, it was boiling over again.
I managed to limp it home. I know it's naughty, but threw a bit of K-seal through it, but it's defo not having it.
Checked again this evening. It boils over, even with the rad cap off and thermostat completely removed. And boils over within 5 mins at idle.
I'm drawn towards it being the cylinder head, as the whole system heats up, even blowers are consistently hot, so I can rule out Water pump and air locks.
My only concern is it being a cracked cylinder head.
So tomorrow I will be pulling it apart. I'm tempted to just pull the whole engine out, as it feels like it needs a clutch anyway. May as well do it all.
I've looked into Vitara conversions, but seems a lot of work to do it from a 410, as I'll need to source all the 413 bits first...
Ben
Ben
