Re: Suzuki Samurai PROECT BORRIS ! UPDATED 30/10/2011
Posted: Tue Nov 08, 2011 11:56 am
i have been doing a bit to my suzuki, i sorted the steering issue by changing the caster angle, all the missing links are now on and my rockbucket from mr rockwatt
but here it is, i managed to get it out the garage, i flexed it up but the front bump stops arnt long enough, so i have that to do, when i flexed it up i also noticed that the rear spings didnt flex that much, hense there will be a lot more flex if i can stop it from lifting the rear wheels and START flexing the rear springs !
but anyway here it is:
the shocks and brake lines are ordered (thanks to dave at llama 4x4)
so when there here i can really crack on, cage, winch wiring, tidy up all the wiring and paint it again underneath, then get it muddy !
here is the spec up to date:
ORA SPOA SADDLES
ROB STOORR HIGH STEER KIT
1.6 16V VITARA ENGINE MPFI, SPI TANK.
5.1 TRAIL GEAR T-BOX
5.125 VITARA DIFFS
FRONT AND REAR LOCKRITE DIFF LOCKERS
FRONT ROCK ASSAULT HALFSHAFTS AND CV JOINTS
FRONT REARS UP FRONT OLD MAN EMU 3 INCH LIFT SPRINGS
REAR IRON MAN 3 INCH LIFT SPRINGS
REAR 3 INCH LIFT SHACKLES
TRAIL GEAR REARS UP FRONT MISSING LINK SHACKLES
LANDCUISER PROP SHAFTS
POWER STEERING
LWB VITARA VENTED FRONT BRAKES
ROB STORR REAR DISC CONVERSION
34 INCH SIMEX JUNGLE TREKKERS 11.50 WIDE
OFSET SPORTTRACK WHEELS
32MM WHEEL SPACERS
LLAMA 4X4 BRAIDED LINES
LLAMA 4X4 ROUGH COUNTRY 30.5 INCH FRONT SHOCKS
REAR ASTRA SHACKS AND INCLINE BAR
FULL POLYBUSHED
GRANITE BASHERS FRONT DIY BUMPER
WARN M8000 WINCH
SAMURAI INJECTION, WHEEL ARCHES, FRONT END, GRILL.
ORA DIFF GAURDS AND AXLES TRUSSES
mike
ORA SPOA SADDLES
5.125 VITARA DIFFS
POWER STEERING
32MM WHEEL SPACERS
FULL POLYBUSHED
WARN M8000 WINCH
mike
