Page 9 of 32
Re: Ed's wagon
Posted: Thu Jun 28, 2012 10:16 pm
by Darrell
And your after one like this maybe, different shaft - different bearing.
Re: Ed's wagon
Posted: Thu Jun 28, 2012 10:53 pm
by Edweird
Darrell wrote:And your after one like this maybe, different shaft - different bearing.
Darrell, you are an automotive messiah. That bearing in the second diagram is the one I need. Is the number on the left the Suzuki part number?
Anyway, thanks a million.
Re: Ed's wagon
Posted: Sat Jun 30, 2012 6:51 pm
by Darrell
Edweird wrote:Darrell wrote:And your after one like this maybe, different shaft - different bearing.
Yes that's the number 09269-33001
Cheapest I could find doing a "Google"
http://www.mister-auto.co.uk/en/release ... 29!60.html
I believe the clutch is the same so hopefully just the right bearing will sort it.
Does somebody know for sure
Re: Ed's wagon
Posted: Sun Jul 01, 2012 1:03 am
The clutch itself should be the same however have you checked that the gearbox input shafts are the same length.
There are two types of spigot bearings on the 410.
On the early one (like yours will be I imagine??) the spigot bearing is in the end of the crankshaft so the input shaft is longer.
On the later 410s it is mounted in the flywheel and the input shaft is shorter.
I would imagine the 5speed box has the shorter input shaft. If this is the case you are going to need to fit a spigot bearing to your existing flywheel or just get a flywheel off a later 410.
Re: Ed's wagon
Posted: Sun Jul 01, 2012 1:24 am
by Darrell
Good info there Scott
. Just had a look at some diagrams and your spot on with the different bearings.
Does the later bearing fit straight into the early 410 flywheel. If so, really easy fix.
Re: Ed's wagon
Posted: Sun Jul 01, 2012 10:47 am
by Edweird
Dad's not going to like this news. Don't suppose anyone's got part numbers for the spigot bearing and the later type flywheel.
Might be worth making a sticky about this gearbox change, not from this post but an abridged write-up. There's one for mating a 1.6 Vitara engine to samurai gearbox I think.
Re: Ed's wagon
Posted: Sun Jul 01, 2012 12:48 pm
by Edweird
I've just gotten off the talk-box to my ol' pappy. He's not too impressed that I've 'missed' another part.
What would you guys recommend? Change of flywheel and bearing, or will a bearing go in my current flywheel? Anyone got the bits I need?
Re: Ed's wagon
Posted: Sun Jul 01, 2012 9:20 pm
by Darrell
The pilot bearing is part number 08133-62007
The size is 10mm x 30mm x 9mm
The bearing can be brought from any bearing dealer as a 6200 2rsr (2 rubber seals)
Your have to see if your flywheel can take this bearing first.
Re: Ed's wagon
Posted: Sun Jul 01, 2012 10:56 pm
by Edweird
Darrell wrote:The pilot bearing is part number 08133-62007
Thanks Darrell, I'll forward this to my Dad. Does anyone know if this will go into my flywheel, or do I need a later 410 flywheel?
Re: Ed's wagon
Posted: Sun Jul 01, 2012 11:02 pm
I have an F8 in the shop and if its got a flywheel fitted it'll be the same as the one on the yours, not sure if ill be up there until next weekend now though, well unless I go spend an evening painting?
