Page 8 of 9
Re: suzuki steve's 410 build
Posted: Thu Jun 27, 2013 9:55 pm
by suzukisteve
i did too, thats how i found the filler and fiber glass
Posted: Thu Jun 27, 2013 9:58 pm
by dndnk
is that filler a factory fit my rear arches where covered in it
Posted: Thu Jun 27, 2013 10:47 pm
by dan_2k_uk
Cool. If I get a bit of time at work tomorrow I will write it using my full set of VL photos and then move the other posts and input from this thread there and generally tidy it up.
Posted: Thu Jun 27, 2013 10:50 pm
Good stuff. When i do my new front clip with the joggled / over lapped panels i'll ad that method to it.
Unless i make a total cock up of it, in which case none of you will ever hear about it.
Re: Virtual lift Q&As
Posted: Fri Jun 28, 2013 10:21 am
by suzukisteve
guys then I vl the front clip am I gonna need to relocate my battery? as I run a bigger than standard one
Posted: Fri Jun 28, 2013 11:01 am
suzukisteve wrote:guys then I vl the front clip am I gonna need to relocate my battery? as I run a bigger than standard one
Probably not
I have done the biggest possible virtual lift you can while keeping the front clip and my battery is still on the inner wing, I also run a bigger battery than standard, think it's a 064?
Posted: Fri Jun 28, 2013 12:22 pm
by suzukisteve
yeah looks to be an 063 or 064. thats good news then, gonna run a twin battery I think
Posted: Fri Jun 28, 2013 2:15 pm
Posted: Fri Jun 28, 2013 5:14 pm
by turbo-tom
you can go more then Scott if you wanted too!
but i reckon Scott's looks about right before it starts to look gash.
Posted: Fri Jun 28, 2013 9:18 pm
by dan_2k_uk
I run a 063 in the standard position with the VL method I described no problems.
Steve I have edited your first post after the thread split to make this topic make sense, Hope you don't mind.
