Page 7 of 7
Re: My Sj 410 build
Posted: Tue Oct 29, 2013 10:55 am
For the starter motor you either need to find a skinny starter, or grind down the edge of a fat starter so it clears the oil passages sticking out of the engine
As for flex, you would probably get better flex if you put decent lift springs on and used some shorter shackles... You can see in the pic on the jack that the front passenger side spring it upside down and this will ruin them if they aren't already!!!
Re: My Sj 410 build
Posted: Tue Oct 29, 2013 11:01 am
by hensey212
twiss wrote:For the starter motor you either need to find a skinny starter, or grind down the edge of a fat starter so it clears the oil passages sticking out of the engine
Okay thanks for the info on the starter
The springs are flat so there pretty much fucked
Re: My Sj 410 build
Posted: Tue Oct 29, 2013 11:19 am
FYI - Fat one (Mitsubishi)
Skinny One (Bosch)
Alternative Skinny One (Valeo)
You can also use these but it MUST be a D6RA
13 (number 13 is stamped onto label after D6RA)
Re: My Sj 410 build
Posted: Tue Oct 29, 2013 11:43 am
by hensey212
twiss wrote:FYI - Fat one (Mitsubishi)
Skinny One (Bosch)
Thanks for that now the hunt begins for a starter
Re: My Sj 410 build
Posted: Mon Nov 18, 2013 2:33 pm
by hensey212
Well this is the end she's now gone to a new how where she's going to be built properly and used more then I ever did she might even go back on the road in some other form staying in touch with the new owner as I know he's started work on her as soon as I left got a new project everyones going to know what it is
Re: My Sj 410 build
Posted: Tue Nov 19, 2013 4:26 am
by kiwizook
what is it?
Re: My Sj 410 build
Posted: Tue Nov 19, 2013 8:36 am
by hensey212
kiwizook wrote:what is it?
Series 3 landrover
Re: My Sj 410 build
Posted: Tue Nov 19, 2013 11:30 am
by dazerede
WHY
Re: My Sj 410 build
Posted: Tue Nov 19, 2013 6:26 pm
by kiwizook
I regret even asking
you not been folowing the blandrover discussions on here?
