Don't know which way to go now. I wanted to go with shiplap for quite a few reasons. Mainly for neatness and because I thought it would be more weather proof etc.
Looked at a few DIY forums and quite a lot of people are using feather edge with good results and the price diffeence is huge. Also it is less susceptible to leaving gaps if it shrinks a bit.
Here are the prices for the cladding.
Style 1 - Front and Sides Clad and then using WBP ply for rear 2 panels:
WBP Ply to make up Back is about £140. Shown added on in brackets.
Siberian Larch Feather Edge 19mm thick- 25mm overlap £205.92 (£345)
Siberian Larch Shiplap 20mm thick - £379.62 (£520)
Wickes Spruce Shiplap 12mm thick - £219.45 (Only 1.8m lengths) or £258.12 (2.4m lengths) - Would still need treating! (£360) or (£400)
Wickes Pressure treated Feather Edge - £86.24 (Only 11mm thick so not worth it) (£230)
Style 2 - All outside surfaces clad:
Siberian Larch Feather Edge 19mm thick - 25mm overlap £343.20
Siberian Larch Shiplap 20mm thick - £632.70
Wickes Spruce Shiplap 12mm thick - £380.38 (Only 1.8m lengths) or £408.69 (2.4m lengths) - Would still need treating!
I want to go with Larch really for its brilliant properties. Mainly the lack of having to bother treating it for 50 years
I'm starting to think the back sides made of WBP ply idea was just laziness and fully clad would be better.
What would you guys do??
