Hello,
Sorry erm not much to update really, been busy with work.
Rear winch is all welded in now. Just needs painting and wiring up and a second battery fitting.
Old front axle is out, cut all the old trusses and diff guards of it, new axle mocked up with new saddle and trusses, just tacked into place for now. Little bit of mucking about to make the of side truss fit in the bottom, as its so short and has to wrap around the Rockwatt knuckle gussets. Which is proving to be a bit tricky.
Should get some time weekend after next to do some more, it's time I need and there's not enough of it !!
Still need to get some side gears to do my diff with, I have had my diff builder build suzuki diffs for other people and not had my own done yet !!
But anyway, onwards and upwards lads
