Page 6 of 11
Re: SJ410 VBJA Wideboy
Posted: Thu Jul 04, 2013 9:51 pm
by turbo-tom
Looks Good Jay looks like you really have gone to town with that sound proofing. :thumbup:
Posted: Thu Jul 04, 2013 10:10 pm
by Jay18
oh yeaa! lol need a bit more behind the seats and some in the back and it should be sorted, need to make a headliner now as the soundproofing is falling down from the roof lol, im thinking some 3mm ply will make a nice headliner wrapped with van matting...
Posted: Thu Jul 04, 2013 10:24 pm
by turbo-tom
Yep typical suzukis! all there headlinings fall down! same with lawn rovers!
Posted: Sun Jul 28, 2013 10:19 pm
by Jay18
haha yep and this isnt even a suzuki headliner.. ill glue more underlay to the ply when i fit it just to sandwhich it to the roof so it stops the roof vibrating completely..
here is an update on the zuk...
as you all probably know i have fitted a rev counter...
yesturday i finally got round to fitting the new carb ans electronic ignition that ive had for yonks lol.. with help from my dad ofcourse..
not sure the electronic ignition is even working though, it says in the instructions that it is supposed to pulse, so it is meant to light up the LED everytime it fires, so the LED is supposed to flash when the engine is running and get faster as the revs go higher, but the led it perminently on...
think ill be buying the kit off ebay as it comes with a new coil, as you can see my coil looks a right state so it could possibly help anyway...
Re: SJ410 VBJA Wideboy UPDATE 28.07.13
Posted: Sun Jul 28, 2013 11:12 pm
by Darrell
not sure the electronic ignition is even working though, it says in the instructions that it is supposed to pulse, so it is meant to light up the LED every time it fires, so the LED is supposed to flash when the engine is running and get faster as the revs go higher, but the led it permanently on...
To be honest it would flash so many times a second, I doubt if you could see it go off. Even at tick-over..
Posted: Sun Jul 28, 2013 11:14 pm
by turbo-tom
yeah i never see the point of them lights that flash everytime etc but it if you get an electronic ign out of it then thats cool :D
Posted: Sun Jul 28, 2013 11:38 pm
by Jay18
the carb needs a proper tune up, ill be driving ti to work tomorrow night so well see how she goes, think the timing is out a bit aswel so need a timing light and ill do the points aswel, then ill pay someone to tune her up as i dont have a gas anyliser, that is true, it does seem to pulse slightly on tick over..
Posted: Sun Jul 28, 2013 11:50 pm
Gas analayser? Timing light?
I just did mine by site and sound.
I have a timing light, might set mone with it one day. Mine does 65mph easy and has CO2 of 0.18 so probably best i leave it for now.
Posted: Sun Jul 28, 2013 11:58 pm
by Jay18
ive had a go at doing it from listening to it and i just cant seem to get it spot on, cant get it to run as smooth as it has done before with the old carb, but the old carb was knackered, its running to strong, it has a very strong smell of petrol, and my emissions was too high on its mot last year so need to get the emissions right for october..
Posted: Tue Jul 30, 2013 12:54 pm
by Rhinoman
The light on the ignition box is supposed to let you set the static timing without a light. If you turn the engine over by hand does the light turn on and off? I don't see how it could run if the light isn't flashing, are you sure that its wired up correctly? Its many yers since I ran something like this but as a rough guide you should be able to see an LED flicker at any frequency below 200Hz, at 1000 RPM you will get 2000 pulses/min which would be 33Hz.
You should be able to get the carburetion very close to ideal adjusting it by ear.
