Page 5 of 7
Re: My Sj 410 build
Posted: Sun May 05, 2013 10:12 pm
by Darrell
A pic of a couple of 410 starter pics in case you pull it to bits. Not a difficult job, just free everything up, especially the solenoid
Link to "Cranking" section of the workshop manual (413 but near enough)
http://www.4x4.in.th/manual_sj413/chapter9.pdf
Re: My Sj 410 build
Posted: Sun May 05, 2013 10:52 pm
Measure the axles widths, details for different axles is here
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2801
It may well have Sammi axles fitted but the usual way to do it is to cut the perches of the axle and move them in to match 410 axle spacing.
Can't really see much in the photos on my phone.
Re: My Sj 410 build
Posted: Mon May 06, 2013 6:36 am
by hensey212
Darrell wrote:A pic of a couple of 410 starter pics in case you pull it to bits. Not a difficult job, just free everything up, especially the solenoid
Thanks for that might have ago at striping the stater now
Re: My Sj 410 build
Posted: Mon May 06, 2013 6:38 am
by hensey212
Jordi wrote:Measure the axles widths, details for different axles is here
Ill go out tomorrow and measure them
Re: My Sj 410 build
Posted: Mon May 06, 2013 6:41 am
by hensey212
Darrell wrote:Not quite sure what's been going on with the spring mounts, but they look like they could do with a bit of bracing.
Edit, Had a re-read and you said earlier they had been cut off
What a pooh job they made of putting them back on.
Dad I'll sort it
It was abit of a poor job but my dad will sort it or he wil teach me to Weld abit better and ill sort it
Re: My Sj 410 build
Posted: Mon May 06, 2013 6:57 am
by hensey212
I'm up and early this morning going to a car boot then come back and do some work on the sj so it might be a pick up at the end of the day took a pic last night of the spot lights on and is there a rely for the headlights as the are stuck on
Re: My Sj 410 build
Posted: Mon May 06, 2013 6:06 pm
by hensey212
no roof i love the look want a soft top now that goes from the roof to the back
like this
Re: My Sj 410 build
Posted: Mon May 06, 2013 8:32 pm
by Darrell
hensey212 wrote:I'm up and early this morning going to a car boot then come back and do some work on the sj so it might be a pick up at the end of the day took a pic last night of the spot lights on and is there a rely for the headlights as the are stuck on
No relay on the headlights. When do they come on and how bright are they. Do you have one of these hiding under the passenger side dash ?? If so unplug it and see what happens
Re: My Sj 410 build
Posted: Mon May 06, 2013 10:37 pm
by suzukisteve
you can get the fastback roof from moonsoon. i got one a while ago and i love it!
heres the link dude
http://www.monsoon4x4.co.uk/Suzuki_SJ_S ... t_Tops.htm
Re: My Sj 410 build
Posted: Tue May 07, 2013 9:05 am
by hensey212
Darrell wrote:hensey212 wrote:I'm up and early this morning going to a car boot then come back and do some work on the sj so it might be a pick up at the end of the day took a pic last night of the spot lights on and is there a rely for the headlights as the are stuck on
when i put the bulb in the holder it did come on like they where on full beam
