softer suspension
kdalton
Re: softer suspension
Post by kdalton » Tue Aug 25, 2015 9:36 am
so with my lift springs and standard shackles. would putting on longer or bigger shackles make the ride any softer.thanks
Post by ScottieJ » Tue Aug 25, 2015 1:26 pm
kdalton wrote:so with my lift springs and standard shackles. would putting on longer or bigger shackles make the ride any softer.thanks
No, if anything they can make it worse as they will steepen the shackle angle.
If you see any shackles advertised saying that they will improve ride and comfort its a load of crap.
kdalton
Post by kdalton » Wed Aug 26, 2015 10:40 am
right scottie so theres no way to fix .unless I put ruf and longers spring on back. ..on road cars very bouncy on beach on the hard sand you can feel a cockle shell or a cigerete butt..or put standard leaves on.cant handle driving the sierra
Post by ScottieJ » Wed Aug 26, 2015 2:37 pm
what tyre pressure are you running and what shocks do you have?
kdalton
Post by kdalton » Fri Oct 16, 2015 6:19 am
I run 20psi and the shockers are Monroe gt gas shockers.thanks
