Another 1600 conversion thread
Richie
Re: Another 1600 conversion thread
Post by Richie » Mon Feb 25, 2013 6:48 pm
Whats the verdict Jordi? all go to plan and get it finished in a weekend?
Im right in the middle of mine thats why i ask :p
Post by Jordi » Mon Feb 25, 2013 8:40 pm
Erm... RW still has my manifold. The 1.6 is still on the garage floor.
So not quite.
Post by Jordi » Wed May 01, 2013 6:58 pm
Just looked for this thread to make sure i had everything i needed.
Then realised i'm only two months behind where i thought i would have been by now. Everything is still sat on the garage floor.
Where does the time go?
Richie
Post by Richie » Wed May 01, 2013 8:08 pm
Tell me about it, ive been doing mine for almost 3 months and still havent got it running! given up now and doing the suspension instead lol
Post by Jordi » Wed May 01, 2013 8:42 pm
It took some time waiting for parts to arrive and the main thing was time.
I worked all one weekend. Had billing the next weekend. Worked all the following weekend. Spent last weekend in London. Haven't got a clue what this weekend holds.
I have everything now and last week in May off.
I noticed at some point i'd said "have it done in a weekend", shame all the weekends have dissapeared. I'll get i all done that week!
Dropping a few bits off at a local engineeing firm to get cut and drilled for some other mods i'm gonna try and get done that week too. Reinforcing and recovery points.
Then before July it's due MOT and tax. My MOT won't recognise it. Only major original components left from last MOT will be the axles. Rest of the drive line, wheels/tyres and suspension will have been changed.
Post by Jordi » Sun May 26, 2013 8:52 am
If these blocks are so identical why don't the mounts line up?
Other than redriling drivers side is there anything that can be done to get them to line up?
Post by dan_2k_uk » Sun May 26, 2013 9:17 am
I just redrilled it. You can use a spreader plate but theres not much point in the effort. I just remove the c spreader from o/s and drill a single hole.
Post by Jordi » Sun May 26, 2013 9:45 am
Wasnt sure if i could swap mounts about to make them line up.
Cheers Dan.
Post by dan_2k_uk » Sun May 26, 2013 10:01 am
Use all sammy mounts. One will need the hole elongating slightly to fit block and a little notch cut out to allow proper fitting of 1300 clutch cable bracket.
OllieSJ
Post by OllieSJ » Sun May 26, 2013 10:55 am
sounds promising jordi good luck
