RickUK
- Can I have a tow
Post
by RickUK » Fri Mar 20, 2015 9:42 am
Rhinoman wrote:It is not illegal to fit a tube in a tubeless tyre.
I had them fitted on my Isuzu Trooper as the alloy rims started to leak mainly due to a small amount of corrosion on the bead,not a massive amount but enough to release a few lbs a week,tubes had been fitted by the garage to stop the problem.
As far as i am also aware its not illegal but tyres fitters dont like doing it due to the extra work involved i would think,but they certainly cured the problems with my old truck with had AT tyres on,i used them for years without any problems what so ever.
Deceased.
Current wheels.
1995 Zuk
Post
by 1995 Zuk » Fri Mar 20, 2015 2:24 pm
cheers for the advice all .... a newer set will be sourced in the very near future, ... just getting fed up with a few delays to getting out and playing in the thing, but I will enjoy when completed.
Just found a bloody hole in the sills also so soon be more weld than metal work. At least MOT till June so a little while in theory till it needs doing BUT will do as soon as I can tho.
2003 GV1600 sport
1995 Vitara SWB
1995 Zuk
Post
by 1995 Zuk » Fri Mar 20, 2015 2:29 pm
Think I will call the car ELLIE as in White ELLIE(phant) .... thoughts
2003 GV1600 sport
1995 Vitara SWB
1995 Zuk
Post
by 1995 Zuk » Mon Mar 30, 2015 9:57 pm
Fitted a newer shock, have a 2" spacer and the red spring is of my GV
Cost spring £0 and shocks £10 and 32mm wheel spacers £55 posted.
2003 GV1600 sport
1995 Vitara SWB
1995 Zuk
Post
by 1995 Zuk » Mon Mar 30, 2015 10:27 pm
got a hard top roof also. rubbed it down and given a coat of paint or 2. now some lacquer needed
2003 GV1600 sport
1995 Vitara SWB
Post
by Anton » Mon Mar 30, 2015 11:19 pm
Looking good!
1995 Zuk
Post
by 1995 Zuk » Mon Apr 06, 2015 9:32 pm
my 1st long outing in my Vitara, with another vit and 3 discos.
It went well but this was slightly to sticky ...
after a dip in a river to was some off the mud off ...
2003 GV1600 sport
1995 Vitara SWB
Post
by donkeychomp » Mon Apr 06, 2015 10:23 pm
Did you not thing to give the coil a lick of paint? It'll last longer...
1995 Zuk
Post
by 1995 Zuk » Tue Apr 07, 2015 8:59 am
painted the coils red before I fitted them (front and rears). the front shocks (replacements) are in good nick, rears need to be upgraded/replaced very soon.
2003 GV1600 sport
1995 Vitara SWB
1995 Zuk
Post
by 1995 Zuk » Mon Apr 27, 2015 3:32 pm
Car has been running quite well, just a couple of little probs when been out. boiled the water one day but no damage, when topped up it ran A1 for the rest of the lanes.
last night i was out, hit 1 or 2 deepish ruts / holes and exhaust parted company just after the cat !!
MMM rather noisy drive home.
Fortunately I have a straight thro' with cherry bomb on the end off the vit I am breaking.
That will do for now until nearer MOT time when I will need to put CAT back on and shorten the straight thro' to fit
2003 GV1600 sport
1995 Vitara SWB
