Tramps Truck,
- donkeychomp
Re: Tramps Truck,
Good stuff...maybe move the fire extinguisher inside the cab? Looks hard to reach where it is.
Re: Tramps Truck,
Update, small but it's still progress, I had a look inside the passengers side rear wheel arch and decided to get my wire wheel in, unfortunately it was a lot worse than I thought it would be!
Oh well plenty of work,
Then can you remember this?
Well it went to this,
And then this,
I guess I just have the rest of the arch to do now!
And then this,
- Can I have a tow
Re: Tramps Truck,
Mine has gone there. You got off lightly compared with mine.Tramp wrote:
Good work on the arch
Martin.
Re: Tramps Truck,
So I've done a little more today,
I was going to start welding, but got carried away with th angle grinder,
First job, cut the rot out of the arch,
Then whilst the grinder was out off with the sill!
And here are both my old sills
More rust & filler than metal!!!!
I started patching the void in my rear arches, and it all seems to be coming together now, I was a little bit disappointed to find a hole in my inner skin (behind my sill) but whats one more patch eh?
Finally a question to all you knowledgeable types, what's the cable for in the passenger side sill? I know drivers side is interior light.....
- donkeychomp
Re: Tramps Truck,
Im pretty sure its for the handbrake lever switch keep up the good work it will be finished before you know it
Re: Tramps Truck,
My handbrake lever switch goes down the right hand side of the vehicle, but I have no idea if that's something someone did to the vehicle after the fact - because it was routed inside the vehicle, under the seat, to a hole in the bulkhead under the door. Didn't look very OEM.
Re: Tramps Truck,
Good call, it is the hand break lever switch,
I had an hour or so today, so the hole in the footwell/inner sill skin
Then the wheel arch.... I ran a bit more weld (it was already tacked in)
Tbh it isn't my best welding, I struggled in the arch being right handed and trying to get my head in, but it's in, a couple more plates and it will be done,
Re: Tramps Truck,
Great work Luke.
I'm seeing a pretty good meet up in 2016 with some of the long term members trucks coming together.
Re: Tramps Truck,
I might even drive back to the UK in the summer for a meetdan_2k_uk wrote:Great work Luke.
