SJ410 -1985 'Cabrio', engine rebuild
Re: SJ410 -1985 'Cabrio', engine rebuild
It's not using any water what so ever. But it's drinking oil like it's going out of fashion! :(
Chucked new stem seals on today, and it's still smoking.
Not sure if it's smoking less though. Hard to tell.
It's not smoking on tick over, or under acceleration. Purely smoking white/grey smoke, on over-run, that is all. Soon as I get on the power, it clears.
On tick over, I've put my hand over the exhaust, no water in it. Black sooty deposits all over the back end of the truck, inside the tail pipe is thick black soot/oily.
It's running rich (Carb set up is wrong), I wonder if it's washing the bores causing blow-by on the rings?
Just a question regarding the ICV valve. Mine is blanked off completely (Manifold end), and the pipe from the rocker is just fed off to a breather. Has no re-circ at all. Guessing this is okay on these? There's that many bloody breathers and hoses on the carb/mani!
If this doesn't affect the idle it should be fine, so long as the breather is vented. I thought bore wash was fuel entering the oil, and thinning it out providing less lubrication and increased engine wear due to excessive over fueling? So wouldn't bore wash wouldn't be why it is burning oil, unless it has been happening for an extended period and caused accelerated wear of the piston rings?binge wrote:Chucked new stem seals on today, and it's still smoking.
Mmm, I've done maybe 500 miles in it running rich. Been waiting out to get all the bits fitted like exhaust, snorkel etc, before spending the £££ for it setting up on a rolling road. It's a really funky carb and I have no idea how to adjust anything on it. That Vitara conversion is crying out I think. :p
Don't bother with a rolling road - we all tune them "by eye" or "by ear" - I used a colourtune kit (very old school tech, but then so is an 8v 1.3 with an SU carb!)
You might get an extra horsepower or two from setting up perfectly on a rolling road, and maybe an mpg or two. But you could better spend that money on a great engine upgrade (16v?)
Trucks been going well recently.
Need a drivers door external handle. And a side repeater if anyone has any going?
- donkeychomp
Will you post? And how much please mate?
- donkeychomp
- donkeychomp
Sent the handle out yesterday...was with a load of other stuff I had to post and forget what it cost...call it an xmas pressie lol.
