What about sealing it at the exhaust end?more948 wrote:Yer jordi, I understand. I'm using mine on the road a lot so might trying and keep it. As long as I seal it it should be ok.
The Matt Black SJ Project.
- Ladaman
- Suzuki Guru
Re: The Matt Black SJ Project.
high temprature silisone and a big jubilee clip will keep that water tight no?
Just got an internal cage off ebay, so that will be the task for the weekend! pics to follow.
Right the roll cage is on hold as i found a little rust in the seat wells so that got be sorted, however on the way to my mates workshop to get the welder out....... the head gasket went, when i bought the SJ the water pump was on its way out we did a cambelt and water pump but it must of been to late.
So off with the head this week.
Alright guys got the head pressure tested and it failed seems something smashed a hole in the head.... So has anyone got a 1.3 head they would like to sell me? Im in essex but would be willing to pay postage or collect if not to far.
Head gasket is now all done and sorted, the internal cage is going back on ebay, going to opt for an external one later. So next on the list is new shocks, heavy duty rear bumper with lights, then the winch.
What is the internal cage like? Do you have any pictures?
Glad to hear you have the engine sorted and running
scottie, it is made from 2" pipe ,maybe 2.5", it was for a soft top so i have cut it in half and drilled it ready for a sleeve so that i could put it in and out as i have a tin top. if your intrested i can get some pics?
Gents im after the following parts if anyone has them, a Petrol tank gaurd after market or standard and a battery clamp the battery tray restraint strap i mean.
- donkeychomp
Local motor factors...universal battery clamp.
