help needed
Re: help needed
Any luck with it??
Re: help needed
got all the wiring sorted out. just got the fetch the heavy duty starter cables, and I'll crank her up. I'm quite positive it'll work this time. hopefully tomorow
Re: help needed
it's now runnign. thanks for all the help guys, it's why I stick around
https://www.youtube.com/watch?v=chSJ6ilKe_0
Click Here for Youtube Video
- Ladaman
- Suzuki Guru
Re: help needed
Nice one
A great feeling isn't it?
I bet your well chuffed, especially as you've rebuilt the engine too.
- Edweird
Re: help needed
Sounds a happy engine. It'll appreciate a bit more back pressure I think but it sounds like it's pretty well tuned already. Picks up nice from idle.
Re: help needed
so I've ran it a few times, and always saw just the slightest wisp of smoke, and today I saw it came from the rocker cover breather. is this normal as it's not yet run in, or this not a good sign.
If I point the breather into the carb, the idle drops by about 100-150 revs
- Edweird
Re: help needed
The revs drop because the engine is sucking air in through the port where the breather should be. As for the slight whisps of smoke, I imagine it's oil vapour. Nothing sounds out of order to me.kiwizook wrote:so I've ran it a few times, and always saw just the slightest wisp of smoke, and today I saw it came from the rocker cover breather. is this normal as it's not yet run in, or this not a good sign.
Re: help needed
There will always be a bit of vapour/combustion gases in the crank case.
Re: help needed
that's good to know.
btw, it's only temporary without a filter
don't think so, because the carb has no filter of any sorts on it, just sucks straight out of the airEdweird wrote:The revs drop because the engine is sucking air in through the port where the breather should be.
