Head lights
Re: Head lights
Post by ScottieJ » Wed Jun 19, 2013 11:29 am
From the battery there should be 4 wires
2 from the negative.
1 small black wire to the body
1 large black wire to one of the MOUNTING bolts of the starter.
2 from the positive.
1 small one that will have a fusible link that goes to a white and yellow wire
1 large wire that goes to the positive terminal on the starter motor.
OllieSJ
Re: Head lights
Post by OllieSJ » Wed Jun 19, 2013 12:11 pm
okay well im not gona touch it. The thing runs so it works fine without that wire
Ladaman
Re: Head lights
Post by Ladaman » Wed Jun 19, 2013 12:19 pm
ScottieJ wrote:From the battery there should be 4 wires
I would add to that, there also needs to be a large earth strap from the engine to the body, or the throttle cable or similar will be used as a circuit, and melt. As had happened to my Sammi when I originally bought it.
Ooops, re read Scotties post, and there is an earth to the body. Doh!
