Page 3 of 3
Re: vacuum hose on standard 8v carb
Posted: Fri Apr 13, 2012 8:53 pm
by Darrell
I don't know where the vacuum advance is connected for sure, if it's from the carb and not the manifold you may not have gotten vacuum at idle (sorry for that
) Never mind Luke has sorted you out
. On the 413 there is a bunch of pipes coming off the manifold but I thought the vaccuum advance would be the easiest (wrong). I can't see that pipe C on my manifold, is that pic from a 410 or am I just being dumb
Posted: Fri Apr 13, 2012 11:12 pm
by Tramp
Pipe c is from the weber carb - sorry thats my bad as I know your running a standard carb, I can't remember where it connects to exactly on the original carb, I think it just joins the standard carb body where all the other pipes are,
Posted: Fri Apr 13, 2012 11:54 pm
by turbo-tom
Tramp wrote:Pipe c is from the weber carb - sorry thats my bad as I know your running a standard carb, I can't remember where it connects to exactly on the original carb, I think it just joins the standard carb body where all the other pipes are,
thanks for all the help guys
, mr vacuum guage is all fine now in his little holder
