Page 3 of 3
Re: LEAKS....
Posted: Wed Sep 14, 2011 2:06 pm
ha... ha... ha... thanks scott.
Now seems to be an appropriate time to remind you that your zook has been off the road for MUCH longer than mine
Re: LEAKS....
Posted: Wed Sep 14, 2011 2:11 pm
twiss wrote:ha... ha... ha... thanks scott.
modifications/rebuilds are different to repairs
Re: LEAKS....
Posted: Tue Sep 20, 2011 1:00 pm
by Russ24
OH YEAH, WE BE BURNIN' NOW111!!!
rear disc conversion nearly done. just need a few hoses and shizzle
only thing i need right now for the front axle is the drive shaft oil seals.
does anyone no the seal measurement? set of 3 numbers on the seal.
AS THERES A LOCAL MOTOR FACTORS I CAN go them from>
SORRy caps lock. shift button stuck.
i has my kinping bearings felts n rubbers. need seals. then im good to go.
assistence please?
oils seal size... not suzuki part number. not really any good to me.
Re: LEAKS....
Posted: Tue Sep 20, 2011 1:10 pm
I'll give you a clue where to look for all the info you need Russ
http://www.suzukiclubuk.co.uk/phpBB3/ph ... =12&t=2801" onclick="window.open(this.href);return false;
Nice to see you making some progress! where's the pics?
Re: LEAKS....
Posted: Tue Sep 20, 2011 1:18 pm
by Russ24
i has no pics. because i have no pc or camera atm. had an incident at home. lost alot of stuff. so to take my mind off it. i cracked on with anus. using web fone and othe rpeoples computers.
THANK YOU FOR THE INFO> damn shift button.
yeah yeah, i can never find the info pages. because i still CANT NAVIGate this site properly.
Re: LEAKS....
Posted: Tue Sep 20, 2011 1:21 pm
by Russ24
front halfshaft oil seal. is that what i have been calling the driveshaft oil seal?
seal inside axle?
Re: LEAKS....
Posted: Tue Sep 20, 2011 1:37 pm
I'll give you another clue (it says click here for stickies)
Re: LEAKS....
Posted: Tue Sep 20, 2011 1:38 pm
Russ24 wrote:front halfshaft oil seal. is that what i have been calling the driveshaft oil seal?
seal inside axle?
and yes they are one and the same
Re: LEAKS....
Posted: Tue Sep 20, 2011 2:28 pm
by Russ24
ScottieJ wrote:Russ24 wrote:front halfshaft oil seal. is that what i have been calling the driveshaft oil seal?
seal inside axle?
lol cheers
