Page 3 of 3
Re: howdy all
Posted: Sat May 03, 2008 11:39 am
by bourneyo
can you out run a bullet?
Re: howdy all
Posted: Tue May 06, 2008 6:36 pm
by dan_2k_uk
Re: howdy all
Posted: Thu May 08, 2008 12:09 pm
howdy Dan
Looks like the Zukes coming along! so whens it gonna be back on the road boyo? come on hurry up it'll be winter again soon!
Re: howdy all
Posted: Thu May 08, 2008 2:12 pm
by dan_2k_uk
scott i posted on facebook
Trot said ur mate might have a handbrake lever of a 410 i could aquire. Mr angry (gary to u) found his way to my old handbrake cables for my rear drums.
Re: howdy all
Posted: Thu May 08, 2008 7:47 pm
by zook
that a be me then
what do you want the hand brakelever(bearing in mind that the 410 has a smaller handbrake it won't fit in a sammy body) or i have the 2 handbrake cables
karl
Re: howdy all
Posted: Thu May 08, 2008 11:24 pm
by dan_2k_uk
the reason i had to cut the old cables was because they wernt long enough to cope with the suspension lift. Ive got a 410 t-box fitted so i was hoping to use a lever off a 410 and use the drum on that.
If u have a lever it would be good.
Cheers mate.
Dan
Re: howdy all
Posted: Fri May 09, 2008 5:21 pm
by zook
oh i see
i'm in the process of doing that my self and all i done was take your handbrake out of the body and you should have
a bit off studding at the end held on by a pin on the handbrake all i done was get angry out grind it flush and punch it out
and the 410 cable will fit in the hole all i have to do now is just find a way to tighten the handbrake where the adjusters are
hope this helps if not i have the handbrake if you still want it
karl
Re: howdy all
Posted: Fri May 09, 2008 6:08 pm
by dan_2k_uk
gunna spend all day on the anus tommorow so i vill have a look a fabing something then
more fun that way!
Re: howdy all
Posted: Mon May 12, 2008 9:30 pm
by zook
hi dan do you still want that break mate
Re: howdy all
Posted: Wed May 14, 2008 6:38 pm
by dan_2k_uk
sorry bout the late reply. Had internet issues.
Had a good look at it and it looks just as easy to knock something up.
Cheers anyway mate.
C u in the mud soon
