Full float axle oil leak
ferris
Re: Full float axle oil leak
Post by ferris » Mon Oct 05, 2015 4:41 pm
The hub seals on mine were brand new. You have only got to park on a bit of an angle and there is nothing to stop the entire hub being filled with oil and no way for that oil to get out. It probably doesn't help that I do quite alot of miles in mine, probably about 600 miles in the past few weeks.
Got these oil seals for it now anyway, so they should hopefully solve it.
before
after
Post by ScottieJ » Tue Oct 06, 2015 10:28 am
Mines a daily so it sees a lot of miles, good hub seals should keep the oil in, as said I've only had it leak after one of the seals was worn, considering I've been running it for over 2 years and 10k+ miles without shaft seals that's not bad going :lol:
Those seals look like a simple solution for people that do have issues though. where are they from?
Post by Anton » Tue Oct 06, 2015 3:32 pm
Nice solution, Ferris! I thought about finding a bearing that has an inbuilt seal and stuffing it in, but that looks far better.
ferris
Post by ferris » Tue Oct 06, 2015 5:50 pm
They're just from eBay.
Turns out only one side of mine was leaking from the bearing seal. The other was leaking from the hub cover due to the bolts working them self's loose. So maybe I damaged the seal on the leaky side when I first installed it.
Post by ScottieJ » Fri Oct 09, 2015 11:32 am
Might be worth checking the stub axle surface where the deal sits on the side that started leaking, could be pitted or rough causing the seal to wear prematurely?
I check my flange bolts quite often, last thing you want is them failing because they have come loose!
Post by dan_2k_uk » Fri Oct 09, 2015 5:10 pm
I've noticed quite a few stub axles get pitting and wear on that seal face.
ferris
Post by ferris » Sun Oct 11, 2015 10:11 am
That could very well be the problem. I know at least one of mine has some damage on the surface from a previous battle trying to remove a broken bearing.
Post by ScottieJ » Mon Oct 12, 2015 1:31 pm
ferris wrote:That could very well be the problem. I know at least one of mine has some damage on the surface from a previous battle trying to remove a broken bearing.
I have plenty of spare stub axles if you need one
Post by mike harris » Sat Oct 17, 2015 10:22 am
Finge bolts coming loose !! Vain of my offroader !!
I converted mine to studs :) problem solved :)
