Powertrax Lock Right done WRONG
Ladaman
Re: Powertrax Lock Right done WRONG
Post by Ladaman » Wed Dec 31, 2014 4:35 pm
They will run without the washers, but I know I wouldn't do that with mine.
It wasn't a hard thing to sort if you have access to the right equipment. See how you go, but I'm sure we can sort it if you get in trouble.
d_r_1989
Post by d_r_1989 » Sat Jan 03, 2015 11:59 pm
Ladaman wrote:They will run without the washers, but I know I wouldn't do that with mine.
For a change as luck would have it a spare diff had some thrust washers at .75mm as opposed to my 1mm thrust washers locks on and disengages as it should although i havent tried it on the car. That was just with shafts in it.veryy happy though.
So differebt sized washers must be available.
Ladaman
Post by Ladaman » Sun Jan 04, 2015 7:35 pm
:thumbup:
