Page 19 of 54
Re: Anton's build
Posted: Mon Sep 30, 2013 1:41 pm
by Anton
Jordi wrote:Busy again then mate. Sounds the drive train will be silky smooth once it's all done.
I do hope so! It'd be rather annoying to do all that and find something else was wrong and ruining the drive - but there's not much left to overhaul after this!
Ladaman wrote:Nice to hear you are back on with it, so your health must have improved so thats a bonus too.
Teeny bit. It'll be a couple of months before I'm firing on all cylinders again. :(
That's the nature of having a misfiring brainstem, though.
Ladaman wrote:I've just had to change a half shaft, as I found the bearing was shot. I only noticed this when changing the shoes, the cage had disappeared, so you might be lucky.
To check the trueness of the rear axle casing, can you clamp on a straight edge on the end faces and measure the distace/length. Rotate 90 degrees and measure again? Possibly easier and simpler to identify than with a "gadget".
Take it easy.
We'll see - I have a laser level, hopefully that'll be real easy - just plant it on the ground and measure the distance from the bottom of the axle casing to the line, top of the axle casing to the line, and do so again along the length of the axle - if it's true, it should come up with the same numbers all the way along. Very similar idea to yours, only including lasers.
And lasers, much like light sabres and bacon, make everything better. Everything.
turbo-tom wrote:Sounds like a plan are you running back and front arb's?
I have one for each axle, but they're staying in a cupboard for now. I have enough to do!
![;) ;)](./images/smilies/icon_wink.gif)
Re: Anton's build
Posted: Mon Sep 30, 2013 6:17 pm
by turbo-tom
Ooooo how snazy! Younkeot that quiet! Join the locker crew
![:D :D](./images/smilies/icon_biggrin.gif)
Re: Anton's build
Posted: Tue Oct 01, 2013 4:27 pm
by Anton
Re: Anton's build
Posted: Tue Oct 01, 2013 4:57 pm
That might need changing.
Re: Anton's build
Posted: Tue Oct 01, 2013 5:02 pm
by Anton
Naah, those are good for another 100,000 miles at least...
:-D
Re: Anton's build
Posted: Tue Oct 01, 2013 5:08 pm
Anton wrote:Naah, those are good for another 100,000 miles at least...
:-D
I thinks its next 100,000 should be as a baked bean can.
Re: Anton's build
Posted: Tue Oct 01, 2013 5:16 pm
by Anton
Well, it (and the one from the other side) are sitting atop my mums bin awaiting pickup by the Romanian scrappies who operate around here - so they may become exactly that!
Re: Anton's build
Posted: Tue Oct 01, 2013 8:52 pm
by 4x4rick
Anton.. not heard a reply to my PM /tx
im still waiting for those brake lines to be returned....( they not a freebie)
if you'ld be so kind to send them back
thanks R
Re: Anton's build
Posted: Tue Oct 01, 2013 10:16 pm
by Anton
Ooohkay...
Rick - I didn't ignore your text, I just thought I'd send 'em back, job jobbed. I had to get ready for that MOT I was flailing about trying to get done and send back a bunch of stuff that wasn't right (wheel nuts, brake pistons/rebuild kit, LED bulbs that didn't work yada yada), I just thought I'd send the brake pipes back with all that lot. There was about 5 or 6 parcels.
I got it in my head I'd sent them back to ya. Just checked the box I've got the diffs stored in, and...
...they were still there.
Sorry mate! I've just put them in a jiffy bag and printed out a postage label, I'll drop them off at the post office tomorrow and I'll text you the tracking number.
Jeeze, now I feel a right
![Image](http://www.subzerosiam.com/forum/images/smilies/wank.gif)
Re: Anton's build
Posted: Sat Oct 05, 2013 9:33 pm
by Anton
Just need to tune the carb to sort out the emissions, replace the kingpin bearings (all the axle bearings, actually) and we're good to go for MOT2 - revenge of the Suzuki SJ...
