Page 17 of 66
Re: Scottie's Zuke
Posted: Sun Jun 19, 2011 11:27 pm
by Lil_Beastie
are you not putting a small UJ thingy where the spacer is just infront of the steering box (just mine has) or as youve fitted it at an angle it'll be alright?
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 12:00 am
Nah I'm just using the rag joint, with the wedge the shaft on the steering box is lined up with the steering column like the standard stering box is :thumbup:
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 6:12 am
by parrotveasey81
some good progess your making there now,keep it up and you just might make it to kirton in augest :rockin:
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 12:10 pm
parrotveasey81 wrote:some good progess your making there now,keep it up and you just might make it to kirton in augest :rockin:
Hopefully matey :rockin: I'm going to be in the workshop every evening for a few hours from now on until it's finished :weld:
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 1:05 pm
by parrotveasey81
8-) will pop over sometime in the week to have a look and use your taper drill bit
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 1:28 pm
ah Is that what you popped over for when I was at volksfest the other weekend? Karis couldn't remember what you said :lol: yeah no worries!
Did you have that bush in the end? I think you should as I only have 3 of the large ones at home :er: I forgot to say I need 4 tubes for them :doublethumbs:
your a legend cheers matey!
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 4:21 pm
by parrotveasey81
ScottieJ wrote:ah Is that what you popped over for when I was at volksfest the other weekend? Karis couldn't remember what you said :lol: yeah no worries!
yes and yes,i will cut them tomorrow and drop them off in the tool room and see when they can do them :thumbup:
Re: Scottie's Zuke
Posted: Mon Jun 20, 2011 4:25 pm
Fawk yeah! nice one matey! that will mean the body can come off for the final :weld: on it and the sliders and the engine and transmission can go in. then it's just the cage, paint and final fit :rockin:
Re: Scottie's Zuke
Posted: Fri Jun 24, 2011 1:28 am
i ran into a few issues tonight, i flxed it up to measure for my shock and upon closer inspection realised that my tyres were hitting the inner arch at the rear. I noticed the front did the other day but that just needs a bit of trimming :hack:
So i best get my ass in gear and rebuild my sammy axles pretty quickly :smokin: the extra width should sort the rubbing out.
some clearer pics of it flexed up :guns:
Re: Scottie's Zuke
Posted: Fri Jun 24, 2011 8:16 am
by parrotveasey81
about time you fitted the wider axles but then the tyres will rub on the outer arch/footwell on the front and dont say they wont as they are close alread :thefinger:
