Page 2 of 4
Re: Zukenstein gets new body parts
Posted: Sun Feb 09, 2014 9:39 pm
by zukenstein
More…
Trial fitted the pug engine and box to see how it lined up. I am going to use L*and Rover engine mounts for engine, gearbox and tcase. They are cheap at £1.60 each and it means I only have to carry one or two spares for breakage’s. Plus it means I can get something useful off the broken down L*nd Rovers at the side of the trail.
Engine mounting positions were pretty close
This is where the gearbox ends, tcase in standard position, excellent!!! .
Put front wings and bonnet in place to see what hit. Not bad at all really. I thought I would probably do a body lift as mentioned earlier, to clear the intakes/cam cover but my aim is to keep this as low CofG as I can so I am going for an air scoop instead. Going to fit one from a Shogun/Pajero I think.
Posted: Sun Feb 09, 2014 9:42 pm
by zukenstein
More…
Took the gearbox mounting bracket off as the holes underneath in the main crossmember were perfect. Not sure what they were for originally
Cut down FSO prop slid perfectly inside cut down sami prop. Couple of LR mounts in place to set the heights. Managed to line up the output shaft of the gearbox EXACTLY in line with the tcase flange
FSO gearbox mount bracket with new bottom to mount to LR mounts
All in place and tacked
Welded and leved off so hopefully there won’t be any vibration.
Posted: Sun Feb 09, 2014 9:47 pm
by zukenstein
More!
Rears up front RUF. Picture shows rear spring compared to standard front spring with add a leaf. Curve is pretty much the same, giving the same lift but extra length gives more articulation and the ride should be less jarring.
So made up some missing links to suit the extra length. Have looked at various ones including Phil's (Kitesurf) thread and decided I would like to try them with polybushes in the middle. Can't be bothered to muck about with greasing them so thought this would be easier. If its OK for the normal shackle I figured it may work OK for these. Time will tell.
Opened up the clamp around the spring too so they will drop more.
Will be making some bump stops for them to rest against on the front of the chassis.
Tyres Mmmmm!. Kumho KL71 33x12.50x15
Posted: Mon Feb 10, 2014 1:52 pm
by zukenstein
More!
Didn't want to have u bolts hanging down acting like anchors, like this
So I made up some plates
So I could use bolts up from underneath
Fitted Vitara power steering to cope with the 33's. Used this template to make the 'wedge' for mounting
Decided to fit Vitara LWB vented front discs and move the Sami ones to the rear
Sami top Vit bottom
Needed to trim shroud away other than that they bolted right up
New discs, pads all painted
Posted: Mon Feb 10, 2014 1:54 pm
by zukenstein
Posted: Mon Feb 10, 2014 1:57 pm
by zukenstein
Eventually when funds permit I will be getting a winch, so needed a good solid mounting for the bumper and what will also be the winch mount. I have looked at various ways of doing it but again I didn't want to really modify the chassis. I knew it had to be more than just the front two bolt holes that some use. Some mounts I have seen are really scary, a winch and bumper becoming detached at full load and flying through the air will take your head off.
This is what I came up with, It slides up from underneath the chassis and bolts through at 5 points. I drilled and sleeved the passenger side chassis the same as the drivers side where the steering box mounts. There is a plate welded along the bottom edge to make it like the bottom of an 'I' beam. It also closes off the front of the chassis to stop it filling with mud and acts as a stop for the missing links. I will probably put some more substantial tube inside the front chassis tube as well at some point.
The red outline is where I will put a 1/2 inch plate to mount the bumper using 5/8 inch towball bolts
The bolts for the steering box go right through the wedge, mount then chassis
Needed a double pulley on the front for the power steering so turned up an adaptor on the lathe so I could mount a single Vitara pulley to the front of the FSO one.
Skimmed the top surface on the lathe
Machined the back to sit inside the FSO pulley
Power steering pump will be going where the alternator is and alt will be moved further up out of the inevitable muddy water!
Posted: Mon Feb 10, 2014 1:58 pm
by zukenstein
Wanted to fit heavy duty mounts to tcase so decided to use the same L*nd R*ver engine mounts on engine, gearbox and tcase. This means I can carry less spares.
Long arm side bolted straight on but I had to mod the other arm
Compared to a standard zuke mount
Posted: Mon Feb 10, 2014 1:59 pm
by zukenstein
Posted: Mon Feb 10, 2014 2:02 pm
by zukenstein
Made a bracket to hang the alternator high up out of the mud. Used the mount on the front of the engine that is used when the engines are transverse in Pugs
Also made a bracket to mount the Vitara power steering pump
Posted: Mon Feb 10, 2014 2:10 pm
by dan_2k_uk
Great stuff.
Plenty of good fabrication and general chopping and welding of anything possible. I like!
