Passenger alignment
Re: Passenger alignment
Post by Jordi » Tue Feb 04, 2014 7:12 pm
Might need to place a block in to wedge the door open so you can push is further than needed as it will probably flex back out a bit.
Cyprus Geoff
Post by Cyprus Geoff » Tue Feb 04, 2014 7:17 pm
Well that would then be passenger re-location Ladaman!
Post by ScottieJ » Tue Feb 04, 2014 8:33 pm
Looking at the gap, ferris's suggestion should help, just loosen the 2 screws holding the catch for the door latch in the door opening and move it in slightly, might require the door to be shut a bit harder but should help.
