best place to get head lights
Re: best place to get head lights
I had mk1 golf in mine and it was just a plate rivited in for one of the bolts as one dosent have anywhere to go. There is a cut out in the flat that they bolt in on mine. If that makes sense????
I thought to fit mk1 headlights you had to make the light hole about 10mm bigger all the way around. Check out this thread
http://forum.suzukiclubuk.co.uk/vi ... ts&start=0
- ianedwards
- SCUK Addict
Interesting, but is there much gain (light output wise) to be made from fitting those crystal lights compared to the normal sj lights with halogens, they look a lot clearer that sj lights,
Ian.
Ian.
