Add a leaf with spring over axle
Re: Add a leaf with spring over axle
Just read the other topic is £500 from llama for standard size springs or are there lifted ones
standard or lifted depends what you want
Just need standard but really dont want to spend £500 on a set of springs
Unless you want something really special is about £500 a set, mine were +1.5" he gets them made to order.
May have to do add a leaf or try find some secondhand ones for now then
If the springs aren't dead just leave it for now and save up for a full set.
They are complety flat just dont want them snapping while out laning
If they are multi leaf springs I would much rather save and get a set of decent ones... even if a leaf snaps you'll still get home in all likelihood!
If you cant afford the whole set maybe think about getting fronts first (more weight on them) and getting rears later... thats what I've done
Is llama the best place to get them
Why is it that everyone does nt like add a leaf is because they are to hard or is it something else
