Page 2 of 3
Re: G16 into sj410 info
Posted: Tue Sep 05, 2017 6:08 pm
by djc
My '85 Jap 410 already has a 1.3 5spd in it, so not totally original anyway. So I got to thinking maybe a Vit 1.6. First thing is there are 8v and 16v Vit engines around and also maybe carb and F/I variants. I'm actually quite happy with a well-sorted carb set-up (got SU on at moment) but what is recommended and pros n cons please.
Posted: Wed Sep 06, 2017 11:32 am
8v with carb is definitely the easiest, pretty much bolt in and go (with adapter plate and skinny starter motor)
SU should work fine on it with some re-tuning, will probably need a new needle and springs. Easy to get from sucarb.co.uk ... about £20 for both I think
The injection is obviously going to be better, but if you are going to the trouble of wiring it up, 100% go for the 16v instead of the 8v.
The 8v injection is through a throttle body... not much better than carb :P
The 16v injection is multi point.
Posted: Wed Sep 06, 2017 12:02 pm
16v mpfi......Out performs all the others, yes it involves a lot more wiring but it's worth it.
Posted: Wed Sep 06, 2017 2:17 pm
by djc
Thanks Twiss and Scottie - excellent info. I'll go read up on the wiring of a 16v next... but I might like the simplicity of an 8v/carb set-up.
Posted: Wed Sep 06, 2017 4:42 pm
There's not really anything complicated about the 16v mpfi, it's early injection so there not even a huge amount of sensors and it's very reliable.
Posted: Thu Sep 07, 2017 7:06 pm
by djc
Ok, i'm going to start looking for a decent 16v I think - may try a wanted here. Thanks again.
Posted: Sun Dec 16, 2018 10:27 pm
by marve114
Sorry to start up an old thread but I’d like more info on this as I’ve got a bog standard 410
Posted: Sun Dec 23, 2018 12:09 am
by Anton
What would you like to know?
Posted: Mon Dec 24, 2018 12:18 am
by marve114
Is there a thread some place going through the process on a 410 covering engine mounts etc ?
Posted: Fri Dec 28, 2018 6:28 pm
by Anton
:lol:
Yes. This very thread. Check the very first post, Scottie talks all about engine mounts for 410 to 1.6 conversion.
