Page 2 of 4
Re: Brakes seizing on help.
Posted: Sun Jan 12, 2014 1:13 pm
by Ant161
All the brake lines look fine.
Posted: Sun Jan 12, 2014 2:20 pm
by Ladaman
Do you think it has had a calliper change to Vitara brakes then?
If it has, are they on square, I mean the calliper isn't twisting in any way is it? Are these callipers on sliders? Do they move freely?
Posted: Sun Jan 12, 2014 2:30 pm
by Ant161
All moves freely. If I just crack the banjo undone to release pressure everything frees up..
The strange thing is no matter where I relieve the pressure ( banjo, top of flexi, master cylinder ) it frees of. The only thing I can think of is the 6 way valve thing.
Posted: Sun Jan 12, 2014 2:47 pm
by Ladaman
It sounds like a master cylinder issue then.
Can you get if off strip, clean and change seals as needed, or even just swap it for another?
Posted: Sun Jan 12, 2014 3:02 pm
You mean this valve?
Click Here for Ebay Listing
Has your other zook not got one? Also have you tried completely draining the brakes and refilling? Might be some crap stuck in a pipe
Posted: Sun Jan 12, 2014 3:07 pm
by Ant161
I put the other master cylinder on and still no joy and it works perfect on the other one.
I would have thought that by now I have changed the fluid about 5 times with all the bleeding.
The other valve is on my other sj but it ends on ebay tomorrow so don't want to mess about with it incase it sells.
Posted: Sun Jan 12, 2014 5:03 pm
by Darrell
Not sure how the 6 way valve could cause this problem
I only say this because my valve does one front, one rear from either feed from the master cylinder.
It is just your front brakes sticking on ?
Have a look at your valve plumbing as they are not all the same, some only have a 5 way valve and one side does the front brakes alone and the other side the rear brakes.
Posted: Sun Jan 12, 2014 5:36 pm
by Ant161
That's the same as mine. I agree with what you say but it is the only thing I have not changed and I don't know how they work. Is it unheard of for these to fail??? Thanks for the help.
Posted: Sun Jan 12, 2014 8:00 pm
by Darrell
Never heard of one failing.
Just wondering if it's possible for the servo to stick on applying force after you have braked
Strange one this !!
Posted: Sun Jan 12, 2014 8:10 pm
by Edweird
I thought the portioning valve was the gadget near the fuel filter?
