Snorkel Help.
- suzukisteve
- Suzuki Guru
Re: Snorkel Help.
I believe its around 52mm, but bigger the better as you don't wanna restrict the airflow to the intake.
pickle power!
Re: Snorkel Help.
So how about if i came off the air box feed with 2" then stepped it up to 3" then put in a 90degree metal bend out the wing then a short section of 3" pipe to a 45degree metal bend up the door pillar then a lentght of 3" with the intake grill on top?
That would work i reckon.
Re: Snorkel Help.
2" and 3" silicone hose that is.
- turbo-tom
Re: Snorkel Help.
i would try and get most of the snorkel done in metal pipe work and then use rubber/silicone bends etc but That to me sounds like your way would work.
