Temp gauge broke
ferris
Re: Temp gauge broke
Post by ferris » Sat Jul 25, 2009 8:26 pm
Unfortunately its the male connector on the sender that has snapped off. Only other option would be to buy a new sender.
Henry
Post by Henry » Sat Jul 25, 2009 8:43 pm
Ah i get you now.
They wont be much even if you carnt solder it back.
Henry
Kirkynut
Post by Kirkynut » Sun Jul 26, 2009 3:02 pm
This happened to me on our 410. I tried Intermotor and Motorquip senders and both sent the gauge into the red, so they must have had the wrong resistance values.
I could have tried the main dealers to get the right part, but what I ended up doing was taking the sender out, drilling a small hole alongside the male spade connector on the sender into the plastic around it and screwing a small screw into it so it touched what was left of the spade in the plastic. I then soldered the the wire to the screw.
The screw appears to come out every now and then so my solution to that is to Araldite the beggar on after I've srewed it back in, then it should be OK. It seemes to have stayed in for a while now though.
You never know though, your local motor factors might supply the right one for a 413 first time round, it's just all their books gave the same part for me.
Kirky
