speedo ect
hath
Re: speedo ect
Post by hath » Fri Nov 08, 2013 8:37 pm
vehicle speed sensor
Re: speedo ect
Post by turbo-tom » Fri Nov 08, 2013 8:38 pm
ahh okay cheers! :D
Re: speedo ect
Post by mike harris » Sun Nov 10, 2013 11:12 am
Steady on boys !!
Mine runs like a sowing machine !! I spoke to rhino an who told me which wire from the ATM to wore to the clocks.
This vss thingy I don't think has to be plumbed in, as mine has no fault codes and no running issues.
Mike :)
Re: speedo ect
Post by ScottieJ » Sun Nov 10, 2013 11:46 am
Yours probably doesn't ever go fast enough for the vss to come into play mike :lol:
For a road going SJ I would hook it up for optimum engine performance as it is needed for the ecu to adjust settings.
It's not that complicated either http://www.auszookers.com/forum/viewtop ... &hilit=Vss
Re: speedo ect
Post by mike harris » Sun Nov 10, 2013 2:57 pm
That's probably only used if the ecu controls fuel pressure. Mine isn't, and anyway seems fine so I ain't touching it !!
I scanned it the other week not a single fault code, it's brilliant :)
Re: speedo ect
Post by ScottieJ » Sun Nov 10, 2013 5:10 pm
If it ain't broke don't fix it :lol:
