Re: front wheel bearing quesition
Posted: Wed Nov 06, 2013 12:22 pm
and the bearings on the other side to see if water has got in to those as well.ROBBIE wrote:Good point and I would check your diff oil as well
Home of all things Suzuki 4x4
https://suzukiclubuk.co.uk/forum/phpBB3/
https://suzukiclubuk.co.uk/forum/phpBB3/viewtopic.php?t=9047
and rip the cap off to replace it with extended breatherstwiss wrote:Might also be a good idea to check that the breather cap a) actually on the axle and b) isn't stuck open as this will allow water to get in quite easily...
You mean if you don't want your axles full of water every time you go out off roadingtwiss wrote:hahah yeah exactly! (if you can be arsed)
Depends how off road you want to go I suppose! I swear the regular breather caps let water in during just road use!!!ScottieJ wrote:You mean if you don't want your axles full of water every time you go out off roading
